I had a similar problem with the front stick in my RV-8. When the smaller tube is welded in, there is some penetration into the interior, which needs to be ground away so the bushing will slide in. The problem may be with the method of doing the grinding. My sticks (I ordered a second one) were cleaned, but the hole was not perfect, even off center. A fellow RV-8 builder was a machinist, so we trued up the hole, then put the bushing end-wise in a large press. That expanded the outside diameter, and we did it until the fit was perfect. But it also made the insider diameter too small for the bolt. So we put it in a lathe and redrilled it to the exact size. Not an ideal process, but it worked. I'm sure there are better ways. In my view, it is noticeable, and with additional wear, could affect handling qualities for small stick inputs.
Terry Lutz
Flying RV-8
