Closed Thread
Old 03-28-2010, 06:49 PM
Alan Carroll's Avatar
Alan Carroll Alan Carroll is offline
Default SL-30 antenna connector
I was doing some work behind the panel, and found that the right-angle coax connector for the nav antenna had broken into two pieces. Hard to describe without a picture, but the part that attaches to the coax had broken free from part that attaches to the mounting tray (the two parts were still held together by friction).
Does anyone know where to order a replacement for this connector? The original came with the install kit and I'm having trouble finding it in any catalogs. The part is labeled "Delta 4205018N995"; the UPS part number was 162-1008.
Alan Carroll
RV-8 N12AC
Old 03-28-2010, 07:10 PM
Transporter Transporter is offline
Default Coax Connector
Call Steinair; they are a Garmin dealer and can get a replacement to you.
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
Closed Thread
