03-27-2010, 03:05 PM
IO360 cylinder replacement
I have a IO360 A1B6 200HP angle valve in my RV7. #1 has a crack in the head from the top spark plug hole. Engine has 700 hrs since rebuild, oil filter is clean-not making metal, cam looks good. My question is should I replace just the bad cylinder with a certified new cyl or is there rebuilt ones avail. or could/should replace all 4 with ECI expirimental cylinders. Where is the best place to get cylinders. Can I mix cert and exp cylinders. Any suggestions? Thanks
03-27-2010, 03:20 PM
Mike,
Sorry I dont have the phone number but its listed. Try calling Larry Brown of Brown Aviation in Tulsa ok. I dont know where you live but I find Larry very fair on prices and he does nice work. He can probably fix you up with a rebuilt matching cylinder assy.
Ryan
03-27-2010, 04:04 PM
Mike, should you decide on new ECi Exp cylinders, I'm giving away an ECi certificate that I won at LOE last year for 25% discount on a set of New Titan Exp Angle Valve cylinders.
Certificate & Info>> http://www.vansairforce.com/communit...ad.php?t=55888
R. E. "Ernie" Butcher
Friends of the RV-1/Eagle's Nest Projects
"Mentors build the student...
Students build the airplane." -Glen Salmon
Dedicated to the historical preservation of the RV-1 Aircraft
and organized for the purposes of promoting, supporting,
fostering, and engaging in aviation and aerospace education.
www.RV-1.org
www.EaglesNestProjects.org
03-27-2010, 04:12 PM
Yes Ernie, I'm interested, please call me at 541-892-5854 thanks Mike Redd
03-27-2010, 06:16 PM
VAF Moderator
Holy Jugs Batman!
Now this is RV'ers helping RV'ers.
Gary "Seismo" Zilik
Pine Junction, Colorado
RV-6A N99PZ S/N 22993 SOLD
03-28-2010, 06:41 PM
cylinder
Give Moore Performance a call, Edgewater Fl. He has helped me out with one off cylinders.
04-02-2010, 05:33 PM
I was going to use Ernie's 25% off coupon and get the ECI EXP cylinders. I called last monday to ECI talked with Tim, he said they didn't have them in stock but the price was $1,032 and he would call me back to tell me when they could have them done. I thought OK 25% off I'll replace all 4. No call back by Friday so I called another number and talked with Joe. He said $1,738 and about 20 days to mfg. them, I asked how many they had flying and he said I'd be the first. Uh, I'm going to be the guinney pig and for almost what I could get Lycoming cylinders for, no thanks with the other problems ECI is having with cylinders. So in the end I bought 2 refurbished lycoming cyls from Airtec, $500 ea. I would have taken the chance for the $780 ea. and replaced all 4. But $1,500 ea is $6,000 total, too steep for one cracked cylinder.
04-02-2010, 06:15 PM
Fuel for the Fire
Mike, I believe you made the right decision. I do find it interesting that the prices ECi quoted you were not in line with their published price list ( here). An interesting aside however is that I've never won anything in my life until LOE last year when it was announced that I was the 'Big Winner' of the ECI gift certificate. Inasmuch as this discount certificate appears to be not only worthless, it appears further that it may have become a liability to some unsuspecting VAF member. I've decided to BURN IT, and that's all I have to say about that!
Have a Great Day!
www.RV-1.org
04-02-2010, 09:19 PM
mix up
Sounds like there may have been a mix-up at ECI between standard and angle valve cylinders. Angle valve cylinders are a new product they just introduced.
Russell Brown
A&P/IA
"Happiness may never be sensibly pursued as an end in itself, because happiness is the by-product of achievement." -- Northcote Parkinson (paraphrase)
Wasilla, Alaska
04-02-2010, 10:10 PM
They introduced the IO360 EXP angle valve one year ago with no takers yet.
