IIRC, there are mulitple tabs on the washers. Two of them are bent over the corners of the carb. This prevents the washer from moving relative to the carb. The remaining tabs are bent in the opposite direction and secure the bolt.
Many people drill and safety wire the bolts.
Personally, I've always used the lock washers, but may drill the bolts next time. The reason is that these washers are a one time use item, so if you have to disassemble anything, you'll need to get new washers, which are several dollars and several days away. I find this to be a PITA when I'm ready to put stuff back together and go fly.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
