Old 03-26-2010, 05:29 PM
macrafic's Avatar
macrafic macrafic is offline
Default Routing of Electrical Forward of Main Spar
How are most of you side-by-siders routing your electrical from the rear of the plane once it gets to the main spar. Looking for the best way to "hide" everything (will have finished interior).
- down the center to the firewall, up and back through the subpanel to the panel?
- down the sides of the aircraft to just under the sub panel, then up to the sub panel and back to the panel?
- down the sides of the aircraft to just under the panel, then up to the panel?
- combination?
- some other way?
Rich and Cindy Macrafic
Rochester, MN
Flying
Old 03-26-2010, 05:44 PM
odlee odlee is offline
Default All of the above.
I felt it was too crowded to try only one way and still keep some separation between certain wiring groups. Space was also a problem.
It disappears once you have some type of carpet and panel cover in place!
Good luck,
David
RV 7
Old 03-26-2010, 06:16 PM
MCA's Avatar
MCA MCA is offline
All the above. Just too many wires...
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
Old 03-26-2010, 07:33 PM
CNEJR CNEJR is offline
Default I agree with......
Marc, probably will have to use all available.
Chuck Elsey
RV6 Start 7/06- Flying!
N349CE
