The oil hoses are fine if you mount the cooler in the stock (on the baffle) location. I ended up making my own fuel lines to fit my particular routing; it was no big deal. I also had to make my own brackets for the throttle/mixture setup which prompted me to measure for my cables. I don't have the results from that but I remember they were standard lengths from Vans; I'll try to see if it's in the builder's log later today. If you're building a tail-dragger, the brackets from AFP will probably work just fine. Superior/AFP supplied the fuel pump and filter, which will be redundant in the FWF kit, but the rest of the mounting parts you'll need. The Van's kit, overall, was a pretty good fit for me.
EAA Technical Counselor #5357
