Old 03-24-2010, 10:30 AM
pilot28906 pilot28906 is offline
Default Fuel Tank Float Screw Up?
I have bent the rod on the floats in the fuel tanks and the left one is correct, however I have the "sherpards hook" open side facing up on the right side. Is this a problem? The print shows the open end of the hook facing down. The rod is on the centerline of the float and nothing touches in the tank. Is there a chance that the float will come loose from the wire hook? I would replace it but I am thinking that the plastic clips on the sender may not hold up to removing then replacing the rod. Any thoughts?
John Johnson
Murphy, NC
RV7
Old 03-24-2010, 12:37 PM
TerryWighs TerryWighs is offline
IMHO.....it won't come off....if in doubt, why not dab a "SMALL" amount of Proseal. You don't want to change the "floatation" characteristics of the float too much by adding proseal wt.???
RV-8 builder..."Reindeer Man"
Fairbanks, Alaska
http://www.mykitlog.com/twighs
empennage done
Wings done
Fuselage kit 90% done...
Old 03-24-2010, 12:39 PM
jtrollin jtrollin is offline
I did the same thing, emailed the manufacturer and they sent me a new hook for free.
John - Leesburg VA
RV-10
http://websites.expercraft.com/jtrollin/
Phase 1 Complete
Vans Builder Number: 40923
798HJ Reserved
