Mine's not run in conduit, but does have poly tubing over it for chafe protection and of course adle clamps. I do not know how long the cable ended up.
There seems to be a second aft location that I wish I had used. Mine is under the baggage shelf like most but I recently saw pictures of an Odyssey in a battery box in the next bay aft. I'm 240 lbs and my -8 has a constant speed prop so runs up near the front of the cg envelope when I fly solo. As light as the PC680 is, moving it back a couple more feet would probably help at least a little. I should do the math to see how much though.
Which position are you planning on using?
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
