Old 03-21-2010, 08:41 PM
jhearnsberger's Avatar
jhearnsberger jhearnsberger is offline
Default rivet question
I have a few of the dome shaped rivets that the die slipped on while riveting. The factory head has c shaped indentions. Some have two or three c shaped indentions.
Should I replace these rivets?
Jake
Old 03-21-2010, 08:44 PM
Phil's Avatar
Phil Phil is offline
Most likely not if they aren't too severe. Got pics?
They're probably best left alone instead of drilling, damaging the hole further, and then re-riveting.
Keeping the rivetset tight and square with the head will keep it from happening.
I'll bet you're fine.
Old 03-21-2010, 09:09 PM
Transporter Transporter is offline
Default Smiley Prevention
A few tips:
Use a small piece of duct or masking tape on the face of your rivet set. The added friction helps keep the set from sliding on the factory head. You'll only get one or two rivets per piece of tape, but it's worth the effort.
A commercial solution is called "Snap Socs." These are plastic caps that fit around the rivet set. Not cheap, but they last through several rivet sessions and work well. See Avery:
http://www.averytools.com/p-884-snap...-set-caps.aspx
Don't be shy about holding the gun firmly on the rivet. If you have a bucking partner you can steady the rivet set with your fingers.
Good luck
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
Old 03-21-2010, 09:11 PM
Yes sir.
Cessna 150/150
N22190
(KSPH) Springhill, LA
Old 03-21-2010, 09:37 PM
That is a great tip to use tape. I will try that.
Cessna 150/150
N22190
Old 03-21-2010, 09:56 PM
papamike's Avatar
papamike papamike is offline
Jake,
I shoot rivets for a living, and I use tape on my rivet sets. I personally would replace those. Just be careful drilling them out. You're letting the set bounce, like Transporter said. And don't remove the gun until your finger is off the trigger.
Pete Miller
RV-7 Panel and Avionics
N174PM (reserved)
McKinney, TX (T31)
http://smilinpete.com
Old 03-22-2010, 08:26 AM
Thank you.
Cessna 150/150
N22190
Old 03-22-2010, 08:40 AM
terrykohler terrykohler is offline
Default Just One More Thing
Jake:
In addition to tape you might also try using a heavier bucking bar for the larger rivets. Shouldn't take more than a few pulses from your impact gun to properly set a rivet, assuming pressure is OK.
Terry, CFI
RV-9A N323TP
Old 03-22-2010, 09:39 AM
Phil's Avatar
Yeah, a couple of those are pretty rough. I'd probably replace the worst ones.
Phil
Old 03-22-2010, 04:10 PM
Paul Thomas Paul Thomas is offline
Hold the gun tight to the rivet until the noise has stopped and set a lower pressure if you can't hold it straight at the current pressure.
Someone messed with my gun pressure once and I could not set a rivet to save my life; it took me a while to figure out a visitor had "helped" me. All my rivets were bad!
