Old 03-21-2010, 07:34 PM
Phil's Avatar
Phil Phil is offline
Default Alternate Static Valves
I'm going to be installing an alternate static system into the airplane and I'm trying to find a source to acquire valves of various types.
Checking around Spruce, I can't seem to find anything there.
Anyone have a source that sells valves?
Phil
Old 03-21-2010, 07:38 PM
apkp777's Avatar
apkp777 apkp777 is offline
I bought an alternate static kit from SafeAir. I am not going to use it and will be selling it brand new in the original packaging. I forget what they sell it for. If you look and see that it would work for you send me a PM.
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 03-21-2010, 07:41 PM
Phil's Avatar
Thanks Tony. I think I've seen those. Aren't they the one that has the insert that you pull out of the fitting?
If so, I'm looking for one that's a little cleaner in the panel. I really like the Cessna type that you just pull out and the valve opens. But found a few references online for $350!!! Couldn't actually find any for purchase (didn't have the part numbers), but just saw an online discussion about them.
Phil
Old 03-21-2010, 07:50 PM
mburch's Avatar
mburch mburch is offline
I used a pneumatic toggle switch... it was only ten or twelve bucks, if I recall correctly.
More here: http://www.rv7blog.com/2008/11/09/al...tic-air-valve/
mcb
Matt Burch
RV-7 (last 90%)
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 03-21-2010, 08:01 PM
rleffler's Avatar
rleffler rleffler is offline
Here are a couple alternatives......
http://clippard.com/store/display_de...asp?sku=TV-2SP
http://www.mcmaster.com/#6791t13/=6bkk6i
Then there is the Piper approach, which is basically just a schrader valve. I can remembered how upset I was when I purchased the official Piper part to put one in my Cherokee when I found out it was identifical the the fuel drain valves. Piper gave it a fancy important name, then marked it up 3,000%.
I will be going with one of the valves above and I like Matt's approach with a the safety cover.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 03-21-2010, 09:08 PM
apkp777's Avatar
Phil
Yes, the SafeAir alternate static is pretty basic. I think it around $25 so I guess I got what I paid for.
Tony Phillips
Old 03-22-2010, 09:57 AM
Phil's Avatar
Thanks.
I ordered the TV-2SP from Clippard and also ordered an adapter from Avery that is:
1/8" NPT (Female) -> Quick Disconnect
This way I can make it a simple connection in the back of the panel.
Phil
Old 03-22-2010, 10:03 AM
miyu1975's Avatar
miyu1975 miyu1975 is offline
I too like Matt's idea. Matt where and how will the static tubes plug into on the valve and what substance will hold them in place?
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
Old 03-22-2010, 10:08 AM
Phil's Avatar
This is what I mentioned above:
This valve has an 1/8" NPT (male fitting).
I ordered this adapter from Avery. It's 1/8" NPT (female) to quick connect.
http://www.averytools.com/pc-1005-12...traight-f.aspx
Simply shove the static line into the back of the quick connect. The static line will be seated and sealed by an O-ring and its got a retainer to keep the line from coming out. Pretty impressive stuff and insanely simple for the builder.
Old 03-22-2010, 10:19 AM
mburch's Avatar
Just one connection is required - all you need is a NPT thread to quick-connect adapter, as mentioned by Phil above.
I goofed up and ordered a valve with male threads, so I will need to either find a female-NPT-to-tube adapter, or order a new valve with female threads as Phil did.
mcb
Matt Burch
RV-7 (last 90%)
VAF #836
