03-21-2010, 10:04 AM
How to attach flexible LED strip under glarshield?
How have people mounted the flexible LED light strips (mine is from Stein) under the glareshield? I don't know if I need to make provision for easily removing it (should last a long time... but you never know).
Thanks for any info - especially pics!
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
03-21-2010, 10:10 AM
Glue
I just put mine in 2 weeks ago. I debated between Proseal and Goo (Home Depot available adhesive) and went with the Goo. Not a lot of time I know, but the strip weighs almost nothing. You can just make it out if you look at my posted picture on the last page of the -8 project status thread. I mounted it approx 1" out from the panel and it lights everything beautifully.
I don't know why you would ever need a provision to remove it, with 50k-100k hr LED lifespan. Should be easily removed with a razor blade.
Wade Lively
-8, Flying!
N100WL
IO-360A3B6D, WW 200RV
03-21-2010, 10:42 AM
I use two sided sticky tape. Works great.
03-21-2010, 10:44 AM
yep - worked for me, 300ish hrs.
03-21-2010, 11:11 AM
I used proseal. 3yrs flying.
Scott Card
CMW E-Lift
03-21-2010, 01:00 PM
Double sided tape
I have a roll of that nuclear powered double sided foam tape. Used it for my ancient EL strip. Has held fine through the AZ heat.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
03-24-2010, 08:15 PM
nuclear powered double sided foam tape?
Darwin,
Can you tell us more about this tape, I have tried double sided tape plus various glues and still my lights fall down during the Houston Summers.
I might have to go the Proseal route like Scot but don't want to mess with proseal again!!
Jim K
Cypress, TX (T51)
RV 7A-
O-360-Dual P mags-GRT EFIS-Tru-Trak AutoPilot
Flying as of 9/7/08
Finally painted 2/8/13
