Old 03-20-2010, 10:30 AM
macrafic's Avatar
macrafic macrafic is offline
Question Com Antenna Mount
For those of you side-by-siders who mounted your 1 or 2 com antennas just ahead of the main spar, next to each gear leg:
- how far inboard of the gear leg hole did you mount the antenna?
- how close to the main spar did you mount it (or did you go even further and tie the backing plate to the main spar and bottom skin, which would require removing and replacing a few rivets)?
- if you have the Classic Aero interior, I'd love to hear your input, as I want to make sure that the housing for the gear leg mounting covers the antenna mounting also, so I need some guidance as to what my range of mounting locations is here.
Rich and Cindy Macrafic
Rochester, MN
Flying
Old 03-20-2010, 11:07 AM
mark schoening's Avatar
mark schoening mark schoening is offline
Default antenna mt
may not be the answer you are looking for, but sooooo much easier to mount antennas behind spar and stick hardware. No interference with carpet, further away from exhaust, backing plate easy to rivet, and easy to get to. I have Classic interior --
RV-9 -- 0-320 -- 993RV--
Old 03-20-2010, 12:09 PM
shuttle's Avatar
shuttle shuttle is offline
Default Behind the spar
Rich,
I have to agree with Mark that I think behind the spar is a better option.
I have emailed you some photos of of my com antenna mount.
Steve Hutt
West Sussex, UK
RV-7 G-HUTY (not flying yet)
( Tip-UP / TMX-IO-360-M1B / Hartzell 7497-2 / 1x LSE PLASMA III / Dual AF4500's / AF-Pilot AP / 695 )
Old 03-20-2010, 02:08 PM
tommylewis's Avatar
tommylewis tommylewis is offline
Default have two mounted
Rich, I have a 7A with the classic interior and two comm antennas mounted on the belly just ahead of spar. I just went out to the hangar and measured the following: antennas are 2 feet apart, each antenna is 5 inches from gear leg fairing, and back mounting holes of each antenna is 4 inches forward of the belly skin seam. This puts them where the classic gear cover does its job and covers them nicely. Let me know if you need a picture.
Tom Lewis
RV7a N967BT 1900 hrs.
RV10 N143EB 960 hrs.
Granbury, Tx
http://bit.ly/2bnimsZ
Old 03-20-2010, 04:22 PM
macrafic's Avatar
Thanks all, for your reply. I will review and consider (reconsider) all options.
Rochester, MN
Flying
