Old 03-18-2010, 09:40 PM
gcrane01 gcrane01 is offline
Default Replacement battery
Anybody ever used one of the bigger Odossy batteries to replace the Concord 25RG-XC in an RV8. I need the weight in the back so the Odossy ES PC680 which is about 1/2 the weight probably won't work. Any other ideas. Looking for something that lasts a little longer than the Concord.
Old 03-18-2010, 10:36 PM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
2 X PC680? Might be good.
Russ McCutcheon
@rv4welder on Facebook
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 03-18-2010, 11:32 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Welcome to VAF!!!!
Hey Greg, welcome to the force
Good to have you here.
I am using a Odyssey 925 in place of the standard aircraft batt, but is in a 10, not an 8.
Actually fits the tray with a little extra room, needed a spacer installed.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-19-2010, 03:47 AM
ronschreck's Avatar
ronschreck ronschreck is offline
Use two Odyssey PC625's in parallel. I have two 625's independently switched. Can easily start the engine on one while the avionics are powered by the other.
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
Old 03-19-2010, 06:20 AM
turbo's Avatar
turbo turbo is offline
Smile the pc-680
in my o-360 has been fine,light, small and powerful. welcome to the VAF FAMILY.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 03-19-2010, 08:23 AM
Smile Thanks
Thanks to all for your comments. Appreciate your responses.
Old 03-19-2010, 04:26 PM
Larco's Avatar
Larco Larco is offline
If you need the weight, then make a weight out of lead equal to the difference in the batteries and use the lighter battery? Larry
Old 03-19-2010, 10:50 PM
Clark Clark is offline
Default Odyssey 925 "L"
I just replaced my Concorde RG 25 XC with an Odyssey 925 "L". The Odyssey has slightly more weight than the Concorde. The "L" is for the positive post configuration (needed in my application for a replacement for the Concorde). My starter spins faster with the Odyssey.
The dimentions are almost the same (the Odyssey is about 1" smaller in length).
Old 03-19-2010, 11:37 PM
Default Thanks againq
After some measuring and as it turns out a guy in the next hangar, it appears the 925 will work great. I have a high compression engine (10 to 1) so the extra umph in the initial start will be appreciated. Now I have to make sure the prop is backed off the compression stroke or it won't spin it through. We shall see. I'll let you know.
Old 03-20-2010, 07:27 AM
rocketbob's Avatar
Replaced my RG-25XC with one of these: http://www.batteryspec.com/cgi-bin/c...nk&product=311
1/3 the price of a 925, and has better specs. Its almost an exact match for the RG-25XC but the terminals are reversed. I've had mine for a few months and it really whips the Hartzell over even when its cold.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
