Originally Posted by L.Adamson
However, it's a fact, that with a tailwheel RV.............there may be objects in the path, that you may miss..............and clobber enough to do extensive damage. This has been proven by a "well known" forum member....  ...
Being that "well known" forum member, I would go with the taildragger again without hesitation.
My incident, was caused by a low slung trailer left in the middle of a narrow taxiway, lined with tall poles (no S-turning), on the back side of a hill, at a large local fly-in. While a nosewheel might have helped, I watched a Cessna almost taxi into the same trailer after we moved my plane. Thus, having the little wheel up front might have helped but it was still possible to hit that trailer. Call it a tie.
The wheels on an RV aren't really made for rough fields. However, you can have custom gear legs made so you can mount large wheels and tires.
It comes down to what you really want. Build that airplane and don't look back.
