Old 03-14-2010, 11:35 PM
Flying Scotsman Flying Scotsman is offline
Default Securing fuel/brake lines in cockpit
Plans (7A) call for using "foam" between the floor and the cover to secure the fuel and brake lines. I was thinking of using Adel clamps on short Click--Bond studs, but now I'm thinking differently (I already have other uses for the Click-Bonds in mind)...but...what sort of "foam" are people using here? I dno't want something that will age and disintegrate, etc.
Ideas? Pictures?
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 03-15-2010, 05:42 AM
Steve Steve is offline
I used the black/blue foam that was packed around the ends of my wing spars. I trimmed the foam with a razor then slipped 2 thin pieces under the fuel and brake lines. Another 2 pieces above the lines to make the sandwich and it was good to go.
Five Sierra Fox
RV-9A
Utah
Old 03-15-2010, 05:46 AM
terrykohler terrykohler is offline
Default Nylon Block
Just used rectangular nylon blocks which I split with a band saw and then clamped back together and drilled holes thru for the fuel lines. Held together in the middle by a single c-sunk (both sides) machine screw and nut. IIRC, the height of the block was approx. .750, which allowed it to fit well in the tunnel, length was cut to fit between the stringers and depth was only about an inch. Nylon was purchased from the scrap bin of a local plastics distributor.
Terry, CFI
RV-9A N323TP
Old 03-15-2010, 06:48 AM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
I used a black sound deadening material that does not absorb moisture.
http://www.aircraftspruce.com/catalo...oofinstall.php
I used the non adhesive in varying thicknesses for insulation of the cabin and the fuel lines.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
