Cowl & heat muff interference
I tried to finish off my exhaust install today. I installed the lower cowl first to make sure everything clears, but I'm getting some interference between the lower cowl and the cabin heat muff. The muff is mounted on the right pipe of my Vetterman exhaust just after the ball joint. There is an angle at which I can put the pipe so that it doesn't hit the cowl, but then there's only 1/8" between the muff and the cowl and only 1/8" between the exhaust and the engine mount.
Anyone have any ideas? I could probably get a bit more space if I mount the heat muff so that the first part of it clamps around the flange on the ball joint. If what I'm describing isn't clear I can take some pictures next time I go.
Andy Compton, PhD EE
RV-10 - #41414 (building)
RV-9A - N643AC (built,flying,sold,missed)
My blood and sweat, the Wifey's tears
