Old 03-14-2010, 01:00 PM
UnPossible's Avatar
UnPossible UnPossible is offline
Default Trouble Fitting Wings on RV-7A
Hey - the big day to insert the wings for the first time is here, and I'm having some troubles. When inserting both wings, I can't get the rear spar of the wing to go inbetween the two spars coming out of the fuselage.
As you can see in the pictures below, in both cases, the rear wing spar appears to be ~1/16 to 1/8" too far to the rear to fit into the slot. My dad and I fought it for nearly an hour before we gave up.... I have to be doing something wrong. Does anyone else have any suggestions as to how I can get the wings to mate with the fuselage (besides buying them a bottle of wine)?
Jason
Right Wing
Left Wing
Jason Tremble
RV-7A (Flying and Sold)
RV-10 in process (@#$$%# Cabin Top & Doors)
Paid for 2020
Old 03-14-2010, 01:11 PM
Default 7 wings
As I've had my wings on and off, and on and off the past few weeks, Here's my hints. As the rear spar meets the twin attach bracket,
I used a large stotted screwdriver to separate the spacing bewteen two brackets. I've had to do this each time I've installed both wings (quick build)
Regards
Lorne
RV 7a tip-up
Pre-cover MD-RA Inspected.
Old 03-14-2010, 01:29 PM
Mel's Avatar
Mel Mel is offline
From the pictures, it appears that you have the wings angled at a slight forward sweep. Try sweeping the wings slightly aft and inserting the aft spar first.
Also you might try inserting a spacer between the spar carry-through slightly increasing the space.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 03-14-2010, 01:31 PM
As Mel <sorta> pointed out, you have to slide the wings straight in. Any angularity will cause the problem you see.
I lost a night of sleep back in the day wondering why one of my -6 wings just wouldn't fit. The next evening, it slid right in.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 03-14-2010, 01:45 PM
VETE76 VETE76 is offline
[quote=Mel;413991]From the pictures, it appears that you have the wings angled at a slight forward sweep. Try sweeping the wings slightly aft and inserting the aft spar first.
i agree, happened to me. straightened wing and they popped right in.
Old 03-14-2010, 02:20 PM
AltonD's Avatar
AltonD AltonD is offline
Slotted screw driver, spread the rear spar just a little. Also, make sure your rear spar on the wing has been trimmed up per the drawing (38 I think).
BE REAL CAREFUL TO CLEAR THE BOTTOM FUSE OR YOU WILL BEND UP THE SKINS.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 03-14-2010, 04:21 PM
Pat Stewart Pat Stewart is offline
Default Aft Spar
I have built 3 RV's and helped put wings on a dozen others. A slotted screwdriver and a very slight opening of the rear spar was required on every one. Just the tolerence stack up at work, no big deal.
Pat Stewart
Old 03-14-2010, 06:08 PM
Bavafa Bavafa is offline
It also appears that you have not trim the rear spar on the wing yet. You need to trim some based on the measurement in the drawing. Once you trim it, if not already, it helps the wing swing back ward a bit more and fit easier into the slot.
Good luck
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 03-14-2010, 06:18 PM
UnPossible's Avatar
Well the slotted screwdriver did the trick. The wings are in and I have four hardware store bolt in on each side...... on to drilling the incidence.
Thanks again for your suggestions.
Jason
Jason Tremble
Paid for 2020
Old 03-14-2010, 06:30 PM
Lionclaw's Avatar
Lionclaw Lionclaw is offline
Good luck
^^^ Definately make sure this is done before you drill the rear spar attach points. I'd get some plumb-bobs off the front of the wings on a chalk or laser line as well to make sure the wings are in straight. On the 9A, the instructions also had me measure wing-tips to tail to check for equal distances. Once the rear spars are drilled there aren't any do-overs!
Andy Compton, PhD EE
RV-10 - #41414 (building)
RV-9A - N643AC (built,flying,sold,missed)
My blood and sweat, the Wifey's tears
