Old 03-12-2010, 12:16 PM
Darren S Darren S is offline
Default Sharkhide Metal Protectant
Has anyone tried this stuff on their airplane after they polished it ?
http://www.sharkhide.com/mpinfo.html
Seems pretty interesting and a way to protect the aluminum surface and keep it shiny longer ? I am still waffling between polishing my -7 and painting. Polishing I can do and I know the finish I will get. Painting is another animal all together.
If this stuff works as advertised, a polished airplane maybe as easy to clean and maintain as a painted bird.
Darren
Old 03-12-2010, 03:44 PM
FresnoR's Avatar
FresnoR FresnoR is offline
at $60 per quart it may be worth a try.
I wonder how easily it scratches off, or if it leaves a haze.
Rick from Fresno
RV-7A
The art to flying lies in learning how to throw yourself at the ground and miss.
Old 03-12-2010, 08:24 PM
That's what I would like to know too. What does the aluminum surface look like after you wash it and dry it with a Chamois ?
Does this stuff flake off around the rivet heads ? Trap dirt ? Get cloudy after a period of time ?
Hopefully someone out there has tried Sharkhide and can report back.
Darren
Old 03-12-2010, 10:39 PM
Snowflake's Avatar
The website does mention recoating worn areas, says you don't need to remove the existing Sharkhide to do it. Just wipe over the existing Sharkhide, and it melts the original Sharkhide and forms a new coat.
That sounds to me like a chemical process, which makes me a little nervous. What happens if you get it on your canopy? How does it affect painted trim? Vinyl decals? etc. I'd want to polish up a spare piece of aluminum first to test.
Rob Prior
Old 03-13-2010, 05:32 AM
ddurakovich ddurakovich is offline
Not a chemical process per se, but a mixture of polymers dissolved in a solvent. The MSDS shows Xylene and Toluene as the primary constituents (~90%). Most aggressive towards plexiglass, vinyl, and some paints.
Literature also shows that the material is not resistant to hydrocarbons, so fuel spills would be problematic. In fact, they claim that cleaning it off is as simple as wiping down with lacquer thinner. That's good news and bad news depending on where you plan to use it!
I'd try it, but $60 plus shipping (Might also be Haz-Mat surcharges) is a bit more than I want to spend on an unknown......
Dave Durakovich
CFIG, AGI, COMM SEL, VAF# 133
RV-4, N666PR, Finished (Well, at least flying)!
RV-6 - Adopted an orphan!
Detroit, MI
"If you think you can do a thing or think you can't do a thing, you're right."
Henry Ford
Old 03-17-2010, 11:27 AM
vfrazier's Avatar
vfrazier vfrazier is offline
OMG! Please don't use any polishes containing toluene, xylene, or other nasty solvents around your airplane. There are much better ways to easily get a nice shine w/o any worries if you get some on your canopy.
This product pair works very well. The polish is a snap to use with no hard rubbing. Light pressure is all you need. The chemistry does the work. The protectant seals the aluminum for up to a year.
My F1 Rocket is painted, but I use this on my aluminum mag wheels on my truck. It takes about ONE minute to polish a wheel by hand. Wipe off, and apply the protectant and you're good for up to a year.
I apologize for the shameless plug, but this stuff works sooooooo much better than the older metal polishes.
http://www.flyboyaccessories.com/sto...roducts_id=213
We can get it in bulk quantities up to 55 gallon drums too!!
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
