Good day All,
I believe that the flow transducer that AFS is using is an Electronics International part. Is it the red aluminum cube? ( I could be wrong)
We strongly recommend placing the FT-60 (red cube) so that it is the last thing the fuel sees before entering the carb.
If you place the transducer upstream from the pump you will essentially be sucking fuel through the unit. This is not the way you want to use this part.
The accuracy of any fuel flow instruments indications such as total "used" and "remaining" are only as accurate as the flow rates indicated. We have found that by placing the transducer just upstream of the carb you can maximize accuracy.
On an 0-360 our FP-5(L) instruments and our MVP-50 systems we would expect to be less than .10% off of actual at 40 gallons used.
Hope this helps.
Mathew Sharp
Electronics International Inc.
541-318-6060
www.buy-ei.com
