Old 03-12-2010, 06:06 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Default Tip: Flaring Tool Source
Heard elsewhere on the web:
Here is the source for an inexpensive 37? flaring tool some economy minded builders are said to be using:
http://www.summitracing.com/parts/SUM-900311/
If you have used this item, consider submitting your comments or a product review for the benefit of others.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 03-12-2010, 09:12 AM
SMO's Avatar
SMO SMO is offline
Default I have one
This tool works "okay", if you have used the 45 degree flaring tool of the same style there is no difference. Careful usage produces a reasonable quality fitting - never had one leak. However when I started in on the airplane fuel lines I used a Parker Hannifin that my hangar mate had; and then I went and bought one of my own. A little more expensive but almost fool proof (a good thing for me to use!).
The Parker has a setting for the depth of tube before you start flaring, and the point at which the flare is finished is very obvious, the tension escalates rapidly. Perhaps more importantly the Parker seems to be able to clamp the tube without leaving striation marks on it which would create a potential point of failure in a vibratory environment like an airplane.
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
