Yes, installing the Andair is simple. In fact, it was much easier then the airflow performance. I choose to use two gascolaters at the wing roots for fuel filters, so I only had to plumb the pump. Check out these two photos, first is the old airflow performance, which I replaced with the Andair pump. Tubing bent all over the place. It took days to get it right. Compare that to the one feed line and one exit line on the Andair. In terms of installation, the andair was much easier.
