Phil,
The idea is to fit the wings, drill the rear spar, drill the bottom skin overlap into the root rib on the bottom, fab. the fwd spar/tank attach, fit the wing root fairings,take the wings back off, then attach all the nutplates on the root rib. I don't know how you can do the bottom nutplates without removing the wings at least once????
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
