You are so right, nothing ever is -
especially with aircraft. But, then, the question still remains. What type engine will I have?
I wanna believe that since the engine was born an -A2B, it will remain an -A2B. I'm not sure there's a good way to figure it. When the engine turns over for the first time, the mags will be different from the originals specified in the book - mags that aren't even
IN the book. So even though the engine mounting provision is changed and the mags will be different it will still be an -A2B - I guess?!?!.
I don't know enough to fill a thimble when it comes to aircraft engines, (any engine for that matter).
Correct me if I'm wrong (I'll never admit it but), is the following data accurate?
-A2B:
A - Indicates change in Power Section and Rating from
Original Design - "A" being the original design - no change
2 - Indicates Nose Section and in this case fixed pitch - I will still be running a FP prop - no change.
B - Indicates Accessory Section - the only thing that will be different here will be mags.
If I choose to go with, say, Pmags. There is no alphanumeric for Pmags so how does this get classified.
Looking at the list of Lycoming engines and their designation labeling, the last of the 150 hp O-320's is an O-320-E3H. The H was because of a mag change from the previous model - "Same as ?E3D but equipped with S4LN -20 and ?21 Magnetos."
Overthinking this far more than I ever should
(and always seem to do) - the label I will place on this particular configuration will be O-320-A2I
I'll send this information into Lycoming so they can make the necessary immediate changes to their paperwork for future reference. LOL
