Today, I was at Aircraft Spruce West and I noticed they had a new display with the Aera 500, AV8OR, and Quadra side-by-side. One of the ACS techs was setting up the display, so I asked him if I could see a maximum brightness comparison of each unit. He said sure. On a scale of 1 to 10, with 10 being the brightest, I would personally judge the relative maximum brightness/contrast levels as follows: Aera: 10, AV8OR: 9, Quadra: 7. The Aera was clearer and easier-to-read than the Quadra despite the Quadra?s higher resolution. The AV8OR was nearly as bright as the Aera and, in my opinion, was the easiest to use of the three. The Quadra definitely needs a shade. The Quadra?s higher resolution might come to the forefront when well-shaded.
As an aside, I ordered a Quadra about ten days ago (my Airmap 500 could no longer be updated), but I cancelled the order when I discovered that the Quadra does not yet talk to an external GPS Bluetooth receiver (I was hoping to panel-mount the unit). Anywhere Map says that a Quadra software change is in the works to provide the GPS external receiver link. The Duo already supports such a link.
A good friend just purchased the Adventure Pilot iFly 700 ($499), and it?s an impressive unit. The brightness is good; I would compare it with the AV8OR in terms of brightness/contrast. The large 7-inch diagonal screen really makes the North-Up Sectional presentation work. If I can figure out a way to squeeze its overall 7.25-inch width into my panel, I might go for it. Unlimited updates, via USB flash drive, are a very reasonable $69 per year (VFR Sectionals) or $89 per year (Sectionals plus IFR Low-Enroute Charts).
Well, anyway, the GPS portable market is getting interesting. Now, if someone would just come up with a 6-inch-diagonal, super-bright, portable GPS with an overall width no greater than 6.25 inches (avionics stack compatible) and a price less than $1K, I think they?d have a winner. Monthly database updates no greater than $100 a year would make it unbeatable.
See Y'All at Van?s Homecoming this weekend?
Bill
