Old 02-02-2006, 06:09 PM
JimWoo50 JimWoo50 is offline
Angry Need help with crooked bolt
Drilled the quarter inch hole for the bolt connecting the brace to the roll bar and much to my disgust it went badly and turned out real crooked. Edge clearance is ok but it certainly is an eyesore. Any suggestions?
Old 02-02-2006, 06:16 PM
Harvey L. Sorensen Harvey L. Sorensen is offline
any chance of going to the next size bigger bolt and fixing the hole??
Old 02-02-2006, 06:17 PM
Rick6a's Avatar
Rick6a Rick6a is offline
Simply fabricate 2 square tapered shims with a .250 hole drilled in the middle. One shim is to be placed under the head of the bolt, the other on the threaded side. Naturally, a longer bolt must be used now.
Photo illustrates .125 repair stock with excess material still attached for holding in vice or with vice grips. Cut to square, break sharp edges, alodine, prime as desired.
Rick Galati RV-6A "Darla"
Old 02-02-2006, 06:25 PM
dgrayent dgrayent is offline
...Maybe possible to drill (ream) the hole out a little oversize (your choice) and use a bushing with the original diameter and length of bolt?
Don
Cortland,OH
