Old 03-07-2010, 11:36 AM
lucaperazzolli's Avatar
lucaperazzolli lucaperazzolli is offline
Default wood propeller extension
Hi,
have you ever considered the difference between the standard wood prop extension and deluxe prop extension ?
Do you think it's worth about a gap of 260 usd ?
I bought long time ago a standard extension ... what's you thought ?
Bye
Luke
Trento, northern Italy
RV-8 QuickBuild, Catto 3 blade Prop, YO-360-A1A. Status : I-LUKE is Flying - 400 h. and counting
http://www.rv8.it
CrewRV8 team leader
https://youtu.be/VhAkhuqZMQA
https://www.youtube.com/watch?v=he9AFHRO1OY
=VAF= 2020
Old 03-07-2010, 11:52 AM
Daver Daver is offline
Default Saber Engineering
got my spacer from Saber Engineering. It fit perfectly and my Sterba wood prop mounted up just fine.
The prop hub thickness was exactly what my fwd spinner bulkhead was made for - no modification was necessary.
Don't know what others sell but Saber is the way to go IMHO.
Dave
-9A
N514R
Old 03-07-2010, 05:20 PM
N941WR's Avatar
N941WR N941WR is offline
Luca, IMHO, vale la differenza. Il " standard" l'estensione utilizza i bulloni MOLTO lunghi che entrano attraverso il puntello, estensione ed in mozzo. Il " Deluxe" l'estensione utilizza due insiemi di più brevi bulloni. Un insieme per serrare l'estensione al mozzo ed il secondo insieme per serrare il puntello all'estensione. Ci sono due estensioni differenti, una per i puntelli di legno ed una per metallo. Quando vi mettete in contatto con Sam a Saber, se lo assicurerà per ottenere l'estensione, i bulloni, excetera corretti.
In English:
Luca,
IMHO, it is worth the difference. The "standard" extension uses VERY long bolts that go through the prop, extension, and into the hub.
The "Deluxe" extension uses two sets of shorter bolts. One set to bolt the extension to the hub and the second set to bolt the prop to the extension.
There are two different extensions, one for wood props and one for metal. When you contact Sam at Saber, he will make sure you get the correct extension, bolts, etc.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 03-08-2010, 08:26 AM
Originally Posted by N941WR View Post
Luca, IMHO, vale la differenza. Il " standard" l'estensione utilizza i bulloni MOLTO lunghi che entrano attraverso il puntello, estensione ed in mozzo. Il " Deluxe" l'estensione utilizza due insiemi di pi? brevi bulloni. Un insieme per serrare l'estensione al mozzo ed il secondo insieme per serrare il puntello all'estensione. Ci sono due estensioni differenti, una per i puntelli di legno ed una per metallo. Quando vi mettete in contatto con Sam a Saber, se lo assicurer? per ottenere l'estensione, i bulloni, excetera corretti.
In English:
Luca,
AND the bolts can be torqued to their proper values. The extension to flange about 60 lbs and the extension to prop about 35 lbs depending on the prop.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 03-08-2010, 10:43 AM
RV8R999 RV8R999 is offline
Does anyone have any DATA that the standard extension ever had any problems or is this another example of vendor hype invading collective thought? I have not decided yet which way to go but I do know the standard extension has worked for years and years. Sure the delux maybe be better but if the standard is good enough why is better, better?
Old 03-09-2010, 10:35 AM
664781 664781 is offline
Default Standard Extension
I have the standard and it has been on 2 A/C with 2 different props with no problems. It is all about the torque on the prop. Old Prop torque was 25 Ft. Lbs, new prop is 45 Ft. Lbs. Re-torque with each season change to maintain proper torque. I retorque 4 times per year here in Ga.
Your milage may vary....
Kurt Lohmueller A&P, DAR
Powder Springs, Ga
RV6A "Kurt's Toy" - Flying
RV12 - Flying - Sold
