Old 02-02-2006, 11:37 AM
RudiGreyling's Avatar
RudiGreyling RudiGreyling is offline
Angry Quick Urgent? Tapping a platenut?
Hi guys,
I have a quick urgent question:
I?d like to tap out a K1100-08 platenut used for the tank/spar attachment and a AN509-8R9 screw, but don?t know what size tap and thread to use or where to buy it on the internet.
The reason is that one of the platenuts already installed do not have threads!
I do not want to undo and untorque all the other (50+) ready installed screws and nuts on the mated tank & leading edge, in order to drill out one nutplate. (more damage to existing hardware)So I?m thinking of tapping out this one platenut in its place and then using Locktite on that screw to secure it.
You see I live in South Africa (Metric Country) getting imperial taps are difficult if not almost impossible and then very very expensive. I have a friend currently visiting in the USA that I can send it to and he will bring in back to me on his return next week.
I just need to know what size tap to use and where I can Internet order it quckly from (or a set of taps for the RV?s), within the next day or so, to be delivered in time before he leaves the USA.
Can you USA guys please urgently help me with the info?
Thanks in advance,
Kind Regards
Rudi
Rudi Greyling, South Africa, RV 'ZULU 7' Flying & RV 'ZULU 10' Flying
"Science, freedom, beauty, adventure...what more could you ask of life? Aviation offers it all" - Charles A. Lindbergh
Old 02-02-2006, 11:55 AM
Mark Burns's Avatar
Mark Burns Mark Burns is offline
Default Taps available everywhere here in US
Rudi,
The tap you need will be an 8-32 taper tap. You can get these at any hardware or autoparts store here in the US.
The nutplates are pretty 'hard" steel. Never tried to tap one that had no threads at all, but you should be able to. Use some tapping lubricant.
I've never been to South Africa but I'd be surprised if you couldn't find one there at an autoparts store.
Mark
Mark Burns
Ruston, Louisiana
RV-7A N781CM 1,650+ hrs
FFI FL-24
A&P
Old 02-02-2006, 11:58 AM
DGlaeser DGlaeser is offline
Default Tap
The AN509-8 screws are a regular 8-32 thread (looked it up on Aircraft Spruce to be sure)
Dennis Glaeser
Old 02-02-2006, 12:39 PM
Thermos's Avatar
Thermos Thermos is offline
Rudi,
You can order a 8-32 tap/drill combo from Lowe's, they're a hardware chain here in the States. Here's a link...
http://www.lowes.com/lowes/lkn?actio...i_products&N=0
You can also try the Home Depot website (www.homedepot.com), they have 'em too. There are Lowe's and Home Depot stores everywhere, if your friend has transportation he/she could easily pick one up.
If your friend is in/around Boston, I can lend a hand...
Dave
Dave Setser
RV-7 airworthy!
Nashua, NH (KASH)
Putting the "slow" in slow-build since 2004!
Old 02-02-2006, 02:25 PM
deene deene is offline
Rudi, I agree with the earlier poster's suggestions and would only add one comment/suggestion: go ahead and get a small full tap and die set, one that would cover 6-32 up to 3/8 or 1/2 inch. These can be had for $50-$75 and would be useful for all aircraft hardware that would be found on most homebuilts. The sets also include the needed tap and die holders and some include the associated drills.
Good Luck,
Deene
Old 02-02-2006, 02:47 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Get a set
Good Luck,
Deene
I agree completely with Deene. I'm really surprised you've been able to get by without a tap and die set. You *will* need one before the project is over. I've got one from Sears, and one from Home Depot. They are fine. At Home Depot I bought a couple of extra 6-32 and 8-32 taps, since they are the most commonly used. Since I'm also in "metric country", I didn't want to get stuck if I break one tap.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 02-02-2006, 02:51 PM
dan's Avatar
dan dan is offline
Default Mail
Rudi,
If having an 8-32 tap will be ridiculously expensive to have shipped to you, but it would be cheaper for an individual to simply pop it in a padded envelope and send it via US Postal Service, let me know (i.e. you buy, have it sent to me, I send it to you). I've sent various small things to RV builders outside the US on occasion to help them save ghastly amounts of shipping and import taxes. If I can help, let me know.
If you don't have at least a 6-32 and 8-32 tap, I'd recommend getting those two if not a complete set.
)_( Dan
RV-7 N714D
http://www.rvproject.com
Old 02-02-2006, 05:27 PM
13brv3's Avatar
13brv3 13brv3 is offline
Ditto all the above. I've had to tap two platenuts in the past that didn't have threads. It really wasn't hard to do, and I (obviously) agree that it's your best option. Good luck.
RV-8, SN-80587, built, flown, sold.
RV-3B, SN-10751, rotary engine, built, flown, sold
RV-8, SN-82470, built, flown, sold.
RV-3B, SN-11351, purchased, , flown, sold
A&P - 2018
Old 02-03-2006, 05:17 AM
Hi Guys,
Thanks this is exactly the info I was looking for and just in time as well...I'll try and order a set from "Lowes" tonight and then it should be delivered in time for my friend to bring home to me in South Africa.
PS: Thanks for the offers to forward, I'll bank them for later.
Kind Regards
Rudi
