Ron, to start - check out Ron Schreck's great post from a couple days ago:
www.vansairforce.com/community/showthread.php?t=51286
What is your mission? Do you want to leave open the option for doing competition-style negative G maneuvers? If not, you can "flip 'r upside down", all you want...you just can't sustain inverted flight. You can be inverted under positive G with no fuel/oil delivery issues. Oil pressure will immediately drop off with the onset of negative G. Unless you have an inverted system that will re-establish oil pressure under negative loading, you don't want a lack of oil pressure for more than a few seconds.
That being said, it would be pointless to have a flop tube if you will NEVER install an inverted oil system. Why not install both the flop tube and inverted oil system now, while it's much easier? Then the capability will be there whether you use it or not.
