__________________ Mel Asberry, DAR since the last century.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
...that Lycoming ships with a flared fitting pre-installed in the optional "oil to cooler" port, but does not put one in the "oil from cooler" port....
Is there also a fitting in the usual "oil to cooler" port in the center of the accessory case?
__________________ Gil Alexander EAA Technical Counselor, Airframe Mechanic
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
I am yhe owner of this engine and no, there is not a fitting in the other oil to cooler port. I think I will have to use the other port because the breather line is blocking the fiting in question. Thanks for the help!
