Old 03-04-2010, 08:30 AM
prkaye prkaye is offline
Default too much loctite
The instructions for my Sabre prop extension said to use Blue Loctite. Never having used the stuff, I just slopped a whole bunch on the threads. A local builder later told me that I should only have used a small amount (a few drops).
By putting too much loctite in these critical bolts, could I have created a danger? Or is the problem simply going to be that if I ever had to remove the extension it would be difficult?
Basically, can too much loctite actually weaken a torqued fastener?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 03-04-2010, 09:28 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Phil, I think that is one you should contact the factory about.
Personally, I dont see how it could affect the strength of the bolts, until you try to remove them that is.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-04-2010, 10:16 AM
Noah's Avatar
Noah Noah is offline
Blue Loctite is an anaerobic adhesive, meaning it sets up when screwed together and air is excluded. By using "too much", you just have a lot of wasted fluid that didn't get into the joint between threads. The stuff in the joint will set up while the extra will not harden and will just drip off (or can be cleaned off with a rag). There is no risk to using too much, it will not make the parts harder to separate. As long as it doesn't drip onto or get into some adjacent component (alternator?) where it could set up and wreak havoc you will be fine.
Highest Regards,
Noah F, RV-7A
All men dream, but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men? for they may act their dream with open eyes, to make it possible. -T.E. Lawrence
Old 03-04-2010, 10:22 AM
Transporter Transporter is offline
Default Loctite
Blue Loctite: no worries.
Red Loctite would be a different discussion
Good luck,
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
Old 03-04-2010, 10:48 AM
Noah's Avatar
Good luck,
Mike
Ummm, why is that?
Highest Regards,
Noah F, RV-7A
Old 03-04-2010, 10:49 AM
David_Nelson's Avatar
David_Nelson David_Nelson is offline
Default How long to set?
I've often wondered how long it takes for loctite to set. Seconds, minutes, hours...?
/\/elson
RV-7A Tip-Up
NW Austin, TX
Old 03-04-2010, 10:56 AM
Noah's Avatar
http://tds.loctite.com/tds5/docs/242-EN.pdf
Highest Regards,
Noah F, RV-7A
Old 03-04-2010, 12:01 PM
Flyfalcons's Avatar
Flyfalcons Flyfalcons is offline
Originally Posted by Noah View Post
Ummm, why is that?
Because if you use gobs of red then you might as well have welded the part on.
Ryan Winslow
Old 03-04-2010, 12:41 PM
Default Very enlightening...
Thanks Noah. Very interesting read. I'd recommend reading it as it has a lot of of useful information.
The comparison of steel vs stainless vs brass vs zinc dichromate was surprising. As was the note that said to heat up the piece to ~250 degC if needed.
<tongue and cheek>Great, another thing that ethanol affects!</tongue and cheek> - see page 2 in bottom right corner.
/\/elson
RV-7A Tip-Up
NW Austin, TX
Old 03-04-2010, 01:28 PM
Default Loctite 271 TDS
Ummm, why is that?
Loctite 271 is labeled as a permanent thread locker. Compare this TDS to the previous one with regard to breakaway torque:
http://tds.loctite.com/tds5/docs/271-en.pdf
I have both types in my shop...but the red is usually locked up to avoid late night mistakes!
Mike
Mike Dooley
RV hitchhiker
RV8 SB
