Old 03-04-2010, 08:25 AM
prkaye prkaye is offline
Default Elevator balance
My elevators are pretty well balanced when not connected to the pushrod. But when I connect the elevator horns to the pushrod, something along the pushrod/bellcrank/control stick assembly is out of balance and the elevators naturally fall downward. Is this normal, acceptable, or is there a procedure to balance the entire assembly?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 03-04-2010, 08:46 AM
Greg Arehart's Avatar
Phil,
I think that's normal. Mine tilt forward when not in use. As long as they're balanced without the attachment, I think you're fine. And you'll have to rebalance the elevators after paint anyway.
greg
Greg Arehart
N 7965A
Old 03-04-2010, 08:51 AM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Same here. It's normal
