Old 02-27-2010, 04:55 PM
eric_marsh's Avatar
eric_marsh eric_marsh is offline
Default Lycoming engine component dimensions
Anyone have a O-320 and/or 0-360 apart on the bench? I'd like to get some measurements and I've been unable to find anything online.
Old 02-27-2010, 06:32 PM
Vern's Avatar
Vern Vern is offline
Default IO-360 parts on the bench
What do you want?
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 02-27-2010, 09:09 PM
Don Jones's Avatar
Don Jones Don Jones is offline
Default My O-320 is scattered...
....all over the work bench. Let me know what you need.
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 02-28-2010, 05:51 AM
eric_marsh's Avatar
Thanks for the response. I'd like the valve sizes and connecting rod center to center length. The camshaft opening and closing points at .050 and lift would be nice but that's probably too much to ask for.
Old 02-28-2010, 06:39 AM
G3i Ignition's Avatar
G3i Ignition G3i Ignition is offline
Default Engine specs.
Hi Eric,
Here you go,
Displacement: Bore /stroke/ rod length/ valve size Intake/ exhaust
540: 5.125?/ 4.375?/ 6.4985? or 6.7485?/ 2.125?/ 1.750?
360: 5.125?/ 4.375?/ 6.4985? or 6.7485?/ 2.125?/ 1.750?
320: 5.125?/ 3.875?/ 6.4985? or 6.7485?/ 2.125?/ 1.750?
On a IO-540-C4B5 same cam specs. @ .050? lift as the AE2A.
Cam specs on my TIO-540-AE2A,
Intake: taken from intake valve retainer:
.005? open 3-BTDC / close 57-ABDC
.050? open 8-ATDC / close 43-ABDC
Total lift .440
Intake: taken from end of push rod :
.005? open 13-BTDC / close 85-ABDC
.050? open 5-ATDC / close 46-ABDC
Total lift .440
Exhaust: taken from intake valve retainer:
.005? open 45-BBDC / close 5-ATDC
.050? open 35-BBDC / close 6-BTDC
Total lift .352
Exhaust: taken from end of push rod :
.005? open 74-BBDC / close 60-ATDC
.050? open 42-BBDC / close 3-ATDC
Total lift .352
New news: Starting to build our aircraft engine dyno facility for break-in and performance mods.
Thomas Shpakow
www.g3ignition.com
Old 02-28-2010, 07:21 AM
eric_marsh's Avatar
Thomas,
Thanks for the specs. I still need connecting rod lengths, if anyone has them.
I think the guys at TPR (oops - sorry Colorado Air Parts) forgot about me, but then again to be fair I've been up to my ears at trying to make a living and have neglected working on this project. I'll bug them again on Monday about parts.
Eric
Old 02-28-2010, 12:03 PM
Default rod length centers
Thomas,
I think the guys at TPR forgot about me, but then again to be fair I've been up to my ears at trying to make a living and have neglected working on this project. I'll bug them again on Monday about parts.
Eric
Eric, above are rod length centers / 6.4985? or 6.7485?/ either or depending on the engine letter code. Pulled them from the Lycoming OH manual
Thomas
Old 03-02-2010, 04:31 AM
Mark Bolton Mark Bolton is offline
Default I have a O - 320 Parts manual as PDF
I havent posted them online yet - probably g docs would be the go.
I have the 0 - 290 Ops Manual which I set up as a html site. The Ops are very relevent to the larger motors.
Have had hassles in the past but will try again.
The main prob is that you cant use ftp on google docs and have to browse every file - fine for the parts manual but unwieldy for the HTML page.
Link to Lycoming O - 320 Parts Manuals
Hope this helps !!
I need to identify a free and reliable web drive to post the other information - not tonight though .
Any suggestions ?
Old 03-02-2010, 05:47 AM
eric_marsh's Avatar
Thanks! I downloaded the PDFs and will study them. Thomas, thanks for the cam and rod specs.
Old 03-02-2010, 10:11 AM
chaskuss chaskuss is offline
Originally Posted by Mark Bolton View Post
I haven't posted them online yet - probably g docs would be the go.
I have the 0 - 290 Ops Manual which I set up as a html site. The Ops are very relevant to the larger motors.
The main prob is that you cant use ftp on Google docs and have to browse every file - fine for the parts manual but unwieldy for the HTML page.
Hope this helps !!
Any suggestions ?
FYI,
Mark's PC-203-1 parts catalog pertains ONLY to O-320 A & E series wide deck engines. I tried to check out the O-290 file, but there wasn't anything there. Am I missing something?
Charlie Kuss
