Old 02-26-2010, 07:51 PM
flickroll's Avatar
flickroll flickroll is offline
Default Shielded cable branch connection
What's the best way to make a shielded branch connection? Consider the following drawing:
http://www.advanced-flight-systems.c...%20Adaptor.pdf
For example, what is the best way to parallel off of the G430 P4001-56 wire to the autopilot?
Would be easy for a non shielded wire, but I'm not sure of the optimum way to do this with a shielded conductor. Thanks
Jim Shannon
RV-8 N52VV
Charlottesville, VA
AFS 4500 EFIS & 3400 EFIS/EM
G430W - SL30 - G327 - G696 - G240
TT DigiFlight II VSVG w/pitch autotrim
VP-X Pro
Old 02-26-2010, 08:01 PM
AltonD's Avatar
AltonD AltonD is offline
solder sleeves. Stein has some of them.
http://www.steinair.com/hshrink.htm
Strip the insulation off the sheild, and shrink this on the sheild.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 02-26-2010, 08:06 PM
RV6_flyer's Avatar
I like to start with at the SOURCE of the signal and run each circuit from the source just like the other branch is not there.
You will need to splice the two branches together at the source.
I wish you were near by so that I could SHOW you how I would do it as it is difficult to type it up.
I would use a single wire from the unit connector. The two wires from the shielded cable would splice into it. I would "Daisy Chain" the shields together and run one ground wire from the shield to the ground.
The drawing you reference does NOT show a shielded wire on P4001-46. If using single wires, I would still do it the way described above. Individual wires spliced together at the source contact or as close to the contact as possible.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 02-26-2010, 08:59 PM
flickroll's Avatar
You're correct, the drawing I referenced doesn't show a shielded wire, but the G430 installation manual shows one out of that pin on P4001. I would think any serial or ARINC cable ought to be shielded.
Jim Shannon
RV-8 N52VV
Charlottesville, VA
VP-X Pro
Old 02-26-2010, 09:07 PM
apkp777's Avatar
apkp777 apkp777 is offline
Get the solder sleeves from Stein. They are a very good way to connect shields.
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 02-26-2010, 09:08 PM
flickroll's Avatar
Are you soldering the branch wires to the parent conductor (wire from the pin), or using a crimp?
If soldered, I'd be worried that eventually the soldered connection at the pin could fail (break). If crimped, I'd be worried that there would be too long of an unshielded wire going into the pin.
Guess I'm a worry wart
Jim Shannon
RV-8 N52VV
Charlottesville, VA
VP-X Pro
Old 02-26-2010, 09:13 PM
flickroll's Avatar
Terminating the shields is not the problem. I have had great luck over the years soldering a shield termination wire to the shield that has been pulled back over the conductor, then using heat shrink over the soldered connection. More labor intensive than a solder sleeve, but also less expensive (virtually nil) and less bulky.
I'm trying to find the best way to essentially have two conductors come out of the same pin. Since you can't put two wires in a pin, a branch connection is necessary.
Jim Shannon
RV-8 N52VV
Charlottesville, VA
VP-X Pro
Old 02-26-2010, 09:27 PM
apkp777's Avatar
Ah, gotcha. Yeah no problem making your own solder connection for the shields. You can still use a solder sleeve (or your method) to splice a wire to make a "Y" connection so that you can use 1 pin supply 2 wires. Raychem makes a nice solder butt splice that you can get from Home Depot. They are cheap and very good quality. I don't think you will see them fail, though I share your concern. I am a little more reluctant to make my own solder splices. Though that too is a pretty solid joint. As you know 2 wires to a single pin is a no, no.
Tony Phillips
Old 02-26-2010, 09:48 PM
apkp777's Avatar
I should add that I have to do the same task in joining the Dynon AP servo wires prior to pinning to the Dynon Network cable. I plan to use solder sleeves (only because I have a bunch) Otherwise I would use the Raychem solder sleeves from Home Depot.
Tony Phillips
Old 02-27-2010, 10:39 AM
az_gila's Avatar
az_gila az_gila is offline
Smile At our Comm....
Originally Posted by flickroll View Post
.... If crimped, I'd be worried that there would be too long of an unshielded wire going into the pin.
...frequencies, the Mil Spec (and some NASA documents) is 2 inches max. for a shield pigtail.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
