Old 02-26-2010, 03:43 PM
CNEJR CNEJR is offline
Default Do RV's use the same cowl?
RV6 & RV7s use the same cowl? How about the RV9?
Chuck Elsey
RV6 Start 7/06- Flying!
N349CE
Old 02-26-2010, 06:58 PM
rvbuilder2002's Avatar
Yes to both questions...with a qualifier...
An RV-7 using an O-320 uses a slightly lengthened cowl and the RV-9 using an O-235 uses the same lengthened cowl. This is because of a slightly longer engine mount for C.G. adjustment with the lighter engines
Scott McDaniels
Hubbard, Oregon
Old 02-26-2010, 07:30 PM
Default Thanks....
for the reply. Working on a little project which might be used on multiple RV's
Chuck Elsey
N349CE
