Poll: have you made access panel in the FWD deck?
Hi.
I'm not quite sure how to make a poll, but I'm trying to see if it works out:
Have you made access panel in the FWD deck?
If so: have you had any problems afterwards?
How many access panel did you make?
How many times have you used them?
Would you do it again?
Would you do anything different if you schould do it again?
If you have NOT made access panels, why?
Because I don't think I'll need them.
Too much work.
Other RV-builders don't recommend them.
Vans doesn't recommend them.
I want a smooth skin on the FWD deck
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
