Old 02-24-2010, 11:02 AM
Jim P's Avatar
Jim P Jim P is offline
Default Old 100LL Fuel Question
For those well-versed in fuels, I drained about 10 gallons of year old 18 month old 100LL from my other homebuilt (yea, I've been flying the snot out of the RV), and re-filled with newer fuel (ground runs haven't eaten up the fuel). I'm now trying to figure out what to do with the old fuel, can I add a couple gallons at a time to the new fuel to mix it up and consume it? I'm just looking for the best way to dispose of that older fuel.
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 02-24-2010, 11:15 AM
N941WR's Avatar
N941WR N941WR is offline
Jim,
There was an article in either AOPA or EAA magazine a few years back on this subject. They said 100LL had a shelf life of two years.
They went on to say mogas is good for one year.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-24-2010, 11:19 AM
Jim P's Avatar
Thanks Bill, I'll do a search on EAA archive and see what I come up with.
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 02-24-2010, 11:40 AM
Danny7 Danny7 is offline
you could always add some to your car, make it around 10%-25% of the fuel and burn it up that way if you didn't want to put it in an airplane.
someone mentioned they use it in their lawnmower
edit, mixing it in the airplane sounds good tome, i was thinking if it was put in a modern car it could foul the O2 sensors if to much at once was used. an older car would probably love it. 10 gallons over a couple tanks in a car probably won't do anything, but on second thought i was thinking i better mention the o2 sensor fouling just in case.
nothing special here...
Old 02-24-2010, 12:11 PM
Jim P's Avatar
If I can find that article, I'd probably just mix a couple gallons at at a time in the RV since that that's been going through gas!
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 02-24-2010, 12:15 PM
Gary 40274 Gary 40274 is offline
Bad idea, I did it and the lead in it tore up the catalytic converter.
Gary Specketer
Old 02-24-2010, 12:18 PM
Gary Specketer
ok, O2 sensors and catalytic converter. what exactly did the cat. do or not do anymore?
Old 02-24-2010, 12:30 PM
longranger's Avatar
The lead in the exhaust precipitates in the catalyst and eventually (more sooner than later) plugs it up. Lots of folks found this out the hard way back when both leaded and unleaded auto fuels were available.
RV-7 TU 904KM (reserved)
Construction Log
Old 02-24-2010, 12:31 PM
airguy's Avatar
airguy airguy is offline
The lead will coat the platinum/rhodium catalyst used in the catalytic converter, poisoning it and rendering it unable to convert the CO and unburned fuel to water vapor and CO2. There is a post-converter oxygen sensor that will recognize this problem and set a trouble flag on the main computer.
Old 02-24-2010, 12:33 PM
Yeah, but what does that mean? The car runs a little rough? i thought the cat converter was in the exhaust and tried to burn up a little more of the exhaust products to produce a "cleaner" exhaust gas, but i kind of thought they stop working after a certain mileage without lead anyway, so does it make a difference in driving?
saw your post greg, thanks. how long do those converters last in normal use?
