Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 02-23-2010, 02:25 PM
elippse elippse is offline
Default Rad props
http://tinypic.com/msm4n.jpg[/IMG]
I tried again and this is what I got.
Old 02-23-2010, 04:21 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Paul, check your PMs.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-08-2010, 10:43 AM
Mike S's Avatar
Senior Curmudgeon
Photos of Pauls props.
Hey, good name for a business
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 03-09-2010, 06:19 PM
breister breister is offline
Are these "E-lippse" propellers?
Old 03-09-2010, 07:24 PM
Danny7 Danny7 is offline
the second one down has elippse on the blade.
nothing special here...
Old 03-09-2010, 07:29 PM
glenn654 glenn654 is offline
Paul,
Are your props designed for all out racing or are these designs suitable for ordinary use?
Have you designed a prop for RVs?
I'm interested in learning how your props perform compared to others.
Glenn Wilkinson
Old 03-09-2010, 10:26 PM
fehdxl fehdxl is offline
Not an expert here, but from what I understand: (a) Paul's props are designed for what you want ... 'ordinary' included; (b) I know of at least one on a RV (RV6).
Give Jim Smith from Wichita, KS a shout at elippsefppropsales@gmail.com
Here's another thread: http://www.vansairforce.com/communit...ad.php?t=52556
-Jim
40603
Old 03-10-2010, 08:21 AM
SteinAir SteinAir is offline
I'm wondering if Paul can give us some independent data on that RV with the prop on it. We've heard for a number of years about the remarkable efficiency of your props, and I thought the goal fo the RV installation was to see what sort of data would result....
Stein
Old 03-10-2010, 08:27 AM
pierre smith's Avatar
Default Absolutely...
...and if there was any way to do a CS prop for a -10, my hat would be in the ring quickly. Makes you wonder what the P-51 could have done with one instead of that paddle.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 03-10-2010, 09:57 AM
Christopher Murphy Christopher Murphy is offline
Default tip flutter
What keeps that thin narrow tip section of the prop from fluttering or flexing? What is the max RPM? It looks like they are pretty small diameter.
Chris M
