DME antenna location
Hi.
In order to meet all antennas distance, I have to install my DME antenna under the tail cone (just in the middle). Antenna will not be "in vertical position when the aircraft is in level flight"; it will be slightly tilted.
As far as I know, DME antenna will work "in sight". So, I guess I will not have major problems with this installation.
Second question: manual says that when coax travel in more than 10', instead of a RG400 one should use a 142B/U. Is that really necessary or may I use a RG400?
Thanks.
Camillo
RV4 IO-320, Catto 3-blade, Christen, I-BILT
Flight time: 1 hour
Status: test flights
www.rv4.it
ROME, Italy
RV9A O-320 D1A, Hartzell C/S prop, slider, I-PRCA
Flight time: 350 hours
Status: SOLD
http://nuke.rv9.it
