Old 02-20-2010, 05:28 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Recommended Gap-Nose wheel to wheel pant
Gents,
I am doing some final trimming of my nose gear wheel pant and leg fairing. I wanted to get recommendations on the appropriate gap from those who have been flying their RV-6A/7A/8A's and have lots of landings (good and bad ones).
1. What is the recommend gap between side lip of the nose wheel pant and the side of the tire?
2. What is the recommend gap between front and back lip of the nose wheel pant and the tire?
3. What is the recommend gap between the wheel pant and the leg fairing. Plans call for 3/16" but that seems a bit to small when the nose gear flexes.
Thanks for your help.
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 02-20-2010, 07:52 PM
trib trib is offline
The advice given to me which has worked (no rubbing) is that you should be able to run your finger between the tire and the fairing. I'd say this is probably about 1/2". As far as between the wheel fairing and leg fairing, This is very small, about 1/8" on mine. There really is very little flex here. The flex occurs along the length of the gear leg. Of course the clearance should exist when the airplane is sitting on the gear, i.e. in the weighted condition.
Tim Ribble
Virginia Beach
RV-6A (only took 13 years to build )
N621TR In unrestricted operation
Old 02-20-2010, 09:12 PM
Ralph Inkster Ralph Inkster is offline
1/2" or a bit more gap adjacent to the tires, plan for the day that tire goes flat. Also the larger gap offers a bit more air circulation for brake cooling.
Ralph Inkster
RV-7A C-GMMJ 650+hrs
Old 02-21-2010, 03:04 AM
plehrke's Avatar
plehrke plehrke is offline
I agree. Finger width and 1/8". 350 hours and no issues.
For the mains you may need to plan for more if you are using the Trainer Tires that come with the kit. They have much rounder corners. Once they wear out (with in a few hundred hours) you will want to upgrade to better tires that have much broader corners and will require making the wheel pant opening bigger.
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
