Also note that Aircraft Spruce sells an "aftermarket" valve that is a drop-in replacement. See
here. Me? I would just get another Van's valve as they can be had for next to nothing with all the folks installing Andair units.
This has probably been covered, but have you tried putting fuel lube on the pipe thread fittings?
