Old 02-18-2010, 05:01 PM
jimgreen jimgreen is offline
Default A tiny crack
I guess I just joined that 'not so exclusive' club. I found this tiny crack at the most forward hole on my canopy. How would you stop drill and repair this?
The hole is just on the inner surface at the moment, but I'm sure with time it will propagate. At the moment I am proposing to make a 1/4" hole about 1/2" away from the screw hole in line with the crack. Then wick some glue into the crack with the runny stuff. Then fill the hole with a piece cut from a 1/4" rod.
Any perspex gurus with advice?
Jim Green
RV7 tip up
IO360 Whirlwind 200RV
Old 02-18-2010, 06:38 PM
frazitl's Avatar
frazitl frazitl is offline
Default I'm no Guru but
I wouldn't drill a stop hole that far away from the end of the crack. I'd bet big bucks (a good beer anyway) that the crack would do it's best to run away from the intended course. I think I'd try just the glue and watch it closely. If it does run, you can stop drill the end of the crack later when it gets a little further away from the big hole.
Good luck...
Terry F.
RV 7A N457RV
250 hours and lovin it!
Southern Nevada EAA Chapter 1300 - www.eaa1300.org
Paid VAF 03/17
Old 02-18-2010, 08:36 PM
What about oversizing the hole and using a larger rivet or a screw?
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 02-18-2010, 10:48 PM
Is this the most forward hole? I think every crack I've ever seen on an Rv canopy has been on the most forward hole (well, except on MINE, which is the rearmost hole). I didn't drill that hole. In this case, would using this hole exacerbate the problem?
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 02-19-2010, 12:23 AM
Thanks for the replies.
Bob, I'm thinking I probably shouldn't put a screw in that hole.
Terry, I think you are right. I can't really stop drill it until the crack moves further away from the screw hole. Perhaps if I don't put a screw in that hole and make sure it's well supported with fiberglass it'll be OK. Yes, I'm whistling.
Jim Green
RV7 tip up
Old 02-19-2010, 12:26 AM
Default I've never had one but ...
This is pure speculation because I have never had the problem but looking at your photo and considering what I would do if I were faced with I would not be able to let it go unchecked. I don't know what kind of access you have but I think I would try to find a tool that would work in that area and try to remove the crack. Maybe a small round file, a #11 X-acto blade, a set of Dremel tools or maybe your countersink tool on the side with the crack would work. What you propose to do sounds bad to me.
Bob Axsom
Old 02-19-2010, 04:21 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by Bob Axsom View Post
This is pure speculation because I have never had the problem........a set of Dremel tools.....What you propose to do sounds bad to me.Bob Axsom
I'm with Bob on this one. Again, pure speculation on my part, because I've never been faced with the challenge. It appears the crack is limited to a small portion of the total thickness of the plexiglas. If that is true, I would be inclined to remove the crack by just barely blending it away primarily using a small round stone, or series of small round stones set in a rotary tool. I suggest you try this method on a small test piece of plexiglas. I think you'll find that deftly using a stone in a rotary tool, you'd have to be a Neanderthal to aggravate an existing crack.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 02-19-2010, 06:37 AM
manuel gonzalez manuel gonzalez is offline
Just run a "red hot" wire through the whole, wide enough to consume the crack.
Not my idea, it came from someone who works with plexiglass for a living.
manny G
RV4 N146ZX
Old 02-19-2010, 06:44 AM
N282S's Avatar
N282S N282S is offline
Default Yip, blend it away.
I agree with Bob, Rick, and Manuel. My very first thought was to melt the plastic. But then I thought, whoa, that's stupid. But...
If you use the grinding stone at even a moderate speed, I think you will melt the plastic - which may not be a bad thing. Sure, its going to change the stresses and structure, but we already do that the moment we stick a drill bit into it. So, I agree with these guys, just try to dress the crack out, blending it into the flat face of the canopy and then polish the area smooth. You have nothing to lose with this method. If the crack reappears, then stop drill it and weld-on glue it.
Old 02-19-2010, 06:45 AM
islandmonkey's Avatar
islandmonkey islandmonkey is offline
manny G
RV4 N146ZX
I suspect just a little bit more information is needed before this is tried. I have never heard of this procedure before and I would be very reluctant to try it on my canopy.
Anthony Johnston
Brit working in Zurich, Switzerland.
1500 hour pilot and ex instructor and examiner.
RV-4 s/n 4572 Emp Kit.
RV-3B s/n 11460 Emp Kit. (In storage).
Anthony's RV-4
