02-17-2010, 05:14 AM
cowl internal finishing
I'm searching an idea to plan an internal cowl finishing then apply a cowl heat protector film.
How you did ? Have a suggestion for me ?
Thanks in advance.
02-17-2010, 05:49 AM
Luke,
I shot some white Imron polyurethane paint on the inside of the cowl. It looks good. It makes it easy to clean any oil drips and reflects the heat a bit. I then stuck adhesive-backed aluminum foil over the hot spots near the outlet and exhaust pipes. You can purchase this foil from Vans.
Don Alexander
RV-8 Finished After 8 1/2 Years (2496 hours) of Loving Labor
Summerville, SC
02-17-2010, 06:56 AM
Luke,
I did something similar to Tinman. After thoroughly washing I skimmed a very thin coat of epoxy (West Systems) over the inside of the entire cowl to fill some flaws and seal the surface. I lightly sanded and used high temp white engine paint on the entire inside. I then added foil to the surface near the hot spots. It's worked fine for 150 hours of flight so far.
Rocky McKiernan
Navarre, FL
N767JM RV-7 Flying
N1011D (res) RV-10 Building
02-17-2010, 07:18 AM
It's also a good place...
....to paint leftover resin after doing fiberglass work. You'll eventually get oil inside the cowl and a nice, slick resin-covered surface makes cleanup easy,
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
02-17-2010, 08:20 AM
I didn't (and won't) bother to paint the inside of the cowl (of course, mine isn't pink ...  ). I simply applied a coat of thinned west systems epoxy to seal the inner surface and then applied the shielding material directly to the cowling where desired. I went back and painted the edges of the shielding with epoxy so that oil/fuel/etc. would not seep under and cause it to lift. The epoxy surface is very easy to wipe clean.
EAA Technical Counselor #5357
02-17-2010, 10:17 AM
Imoron
I did like Tin. Finished inside to pit/void free and shot with leftover Vestal white Imoron. Once oil leaks into glass voids its there forever.
02-17-2010, 10:58 AM
If you wanted a heavy duty finish in a nice gray the fuel tank sealant is resistant to most solvents/ fuels/ oils.
http://www.aircraftspruce.com/catalo...s/tankseal.php
edit- this is commonly used in lancairs retractable gear openings/ enclosures- it gets exposed to the elements but with the coating nothing sticks.
nothing special here...
02-17-2010, 05:24 PM
Luca,
I've finished my RV8's with high temp engine enamel, and didn't bother with the foil. I've had no issues with heat from the exhaust pipes, heck until I flared the stainless exhaust hangers from Vetterman, the pipes would occasionally slip down and ride on the lower cowl outlet. This was after the paint job. I had no scorch marks inside and no bubbling of the paint outside.
Good luck,
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
02-17-2010, 09:15 PM
I did similar to Rocky. I brushed in West Systems epoxy, then brushed on a coat of DP-50 black epoxy primer. It sealed well. I like the white idea for heat reflection tho-....so I'll probably top coat with white.
If you check my link you can see a pic of it, although it's not yet done.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
02-18-2010, 04:34 AM
Same here. I thinned the epoxy 50/50 with acetone and then used a long nap 3" roller to push it into the pin holes. Three coats did the trick.
The epoxy I used was the West System quick hardening type. It is a little brown in color and when I was finished with the cowling you could see where it ran into the foam sandwiched in the cowl. It made it look a bit like cardboard. Sure makes me happy to know it is not oil collecting in there, adding weight and waiting to ooze out on my future paint job.
BTW, I did the same on my first cowl and it worked great.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
