Whirlwind 200RV
Originally Posted by Paul Austin
HI all
Just installed my engine and trying to decide on which proppellor to us i have narrowed it down to a senseich or the whirlwind Ga. Can someone give me some info in regard to weight and balance i Have an RV7A IO-360 and everything is a per the plans the sensenich ia about 40lbs and the whirlwind is only about 28lbs for prop and spacer will this put my CG to far aft or would it still be in the exeptable range any help would be much appreciated
Hi Paul,
You can't go wrong with the Whirlwind. Also, something to keep in mind, the WW comes with a ready to use spinner system. It is done!!!
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
