02-16-2010, 02:16 PM
leaking fuel drain repair......
having a leaking fuel drain i emptied the tank and removed the leaking unit. the o-ring was shot so a trip to ace hardware came up with a replacement part for 20 cents and a few spares. pure genius.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
02-16-2010, 02:24 PM
Buy a spare drain.
Ed,
If you have a spare drain in your emergency kit along with extra O-rings, you can actually change the drain without draining all the fuel. You will only lose a small amount of fuel during the change over. Just be sure to tie a rag around your wrist unless like fuel running up your sleeve.
David
02-16-2010, 05:20 PM
Originally Posted by odlee
Ed,
David
Ditto on that.
I've changed the o ring at OSH by using a 1/8" NPT plug which is screwed in as quickly as possible after removing the drain and doing it again after the o ring is replaced. Those darn o rings sometimes refuse to reseat at the worst times and places and you can't have fuel dripping for a couple days.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
02-16-2010, 05:35 PM
Ed,
David
I was about to say the same thing. If you have a spouse around, their finger on the hole works also, without draining the fuel  . Been there: "Tanya, come over here and put your finger in this drain hole for a second while I pop an new o-ring on the drain." Total time for repair 90 sec., finger usage time, 20 sec., bonding moment, priceless.
Scott Card
CMW E-Lift
02-17-2010, 10:06 AM
Is is necessary to add some fuel lube to help prolong the seal?
Eric
RV-4
Senior Parachute Rigger
02-17-2010, 03:53 PM
O-Rings from McMaster-Carr
Got my O-Rings from McMaster-Carr part # 9464K11. They work great and hard to beat the price ($4.48 per 100).
Squeak
Master-Carr
9464K11(Same as 9464K342)
Viton? Fluoroelastomer O-Ring AS568A Dash Number 006
In stock at $4.48 per Pack
This product is sold in Packs of 100
04-09-2010, 03:38 PM
Is the drain suppose to screw all the way flush? I've got mine in about half way and to go any further worries me.
04-09-2010, 04:14 PM
It's a tapered pipe thread. Screw it in as tight as you dare without flexing the tank skin too much. It doesn't have to be flush.
Jim Sharkey
RV-6 Phase 1
04-09-2010, 04:20 PM
I put fuel lube on mine but suspect that it was the sticky lube that trapped a tiny piece of debris that prevented the darn thing from sealing and caused a leak. The debris, a tiny aluminum chip, would otherwise have been flushed out when I sampled the tank.
Jim Sharkey
RV-6 Phase 1
04-09-2010, 05:47 PM
Aluminum chips on fuel drain
I rinsed the h*!! out of my fuel tanks, including sloshing fuel, running fuel through a throw-away filter and fuel pump and back to the tank for two days, etc. I still managed to shake a couple of chips loose after first flight and have had to clean my O-rings twice. I didn't use fuel lube on my O-rings.
Scott "Grumpy" Stewart
RV-7 N957RV (First Flight on Dec 18, 2009 )
#866 on the Van's RV-7 hobbs
#6563 on Van's generic hobbs
Arlington, WA
