Tom, a lot depends on your mission
If you'll be doing solid IMC approaches to 200', I'd recommend an SL 30 for a second nav source.
If you are NOTgoing that low but maybe to 600' ceilings, it's a different story and only the 430 with Trutrak ADI ought to be OK, in case of 430 failure.
Decide how you're going to fly and it'll make your decision a little easier. I just installed a 430W in my -10 and have the SL-30 as a second nav source mainly because the airplane came with it, and the HS-34 module coupled to the D-100 can select either nav source with a push of a button.
It still leaves you in a quandary if you're making a GPS approach to an airport without an ILS and the 430W goes TU.
I do have a 496 for emergency backup though.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
