Old 02-14-2010, 09:57 AM
msturgis's Avatar
msturgis msturgis is offline
Default Good deal on an engine?
I found an IO-360-A1A ,1400smoh, all logs, compresions in the 70s, but has had a prop strike and the crank flange is shot.
The intersting part is I can get this for under 3k.
Any thoughts if this might be worth going after? How much would a complete tear down and over haul typically cost with needing a new crank?
Matt Sturgis
RV-8, Wings
N43MS Reserved.
Paid VAF 2012
www.mattsairplane.com
Old 02-14-2010, 12:01 PM
rv7charlie rv7charlie is offline
sounds tempting, especially to someone like me, who's always looking for a 'deal'. It might be worth that much, just to part it out. (Assuming that everything is still on the engine.)
But if you plan to overhaul, price that crank, then remember that if the crank is trash, there may well be other expensive parts that got damaged at the same time, and the cylinders are at 75% of tbo, even if they are still good.
Charlie
Old 02-14-2010, 12:32 PM
Danny7 Danny7 is offline
I was told earlier last year a tear down and overhaul would be about 15,000 by a reputable commonly used engine company. This did not include replacing the crank.
$3000 is about what cores are worth, give or take. If it has all the accessories you might save a couple thousand, but I'd have every accessory connected to the crank inspected
nothing special here...
Old 02-14-2010, 04:49 PM
hudgin hudgin is offline
If you have to pay someone to do a tear down inspection by the time he finishes with the parts needed list you will be very close to what a rebuilt exchange will cost from Lycoming. I have done this for many customers over the years including myself. I saved $5000 by not charging myself labor after all the surprises were over with. So what did I save? I get to go to my self for warrenty. If you don't do the whole overhaul at the same time you will be working on the engine every other day. To me that is as frustrating as bad weather.
member 1 of 6
Metal Feathers Club
RV 7 N706CB
1st flight Oct 18, 08
S/N 72847 tip 200HP CS glass IFR
Old 02-14-2010, 05:46 PM
OceanBob OceanBob is offline
Default I would say no.
Several reasons. 1400 SMOH doesn't mean the cylinders and cam shaft are good now or good to Factory Fresh TBO.
The main reason is that major overhaul 1400 hours ago might have included using parts that were perfectly legal; with-in 'service limits'. For example the Pistons might have been bead blasted clean and they mic'ed out within service limits then reinstalled. Those pistons might have gone past the wear limits at 900 hours and would have to be replaced at the next overhaul.
Same for the cylinders. They may have been chrome plated and now are beyond limits; or ground ten over and are now out of limits; ten over pistons are more expensive. You already know the crank is toast; maybe they re-used the original camshaft and now the cam is out of limits ($). Same for the lifters, piston pins and the gears on the crank and mags.
Old 02-14-2010, 08:20 PM
msturgis's Avatar
Good points... Thanks for the info..
Please forgive my ignorance with this engine stuff, but would there be any vlue in using it as a core?
Matt Sturgis
RV-8, Wings
N43MS Reserved.
Paid VAF 2012
Old 02-14-2010, 08:31 PM
hydroguy2's Avatar
you're looking at $3k+ for a crank to put in this unknown core. So if you want a $6000 core which you don't know the condition of the case, cam or cylinders. It could still work depending on what the TT is on the rest of it. If the seller will guarantee to other stuff will yellowtag, might be worth it.
Old 02-14-2010, 08:34 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Default Sign...
me up... I'm all over it.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 02-14-2010, 08:50 PM
jrs14855 jrs14855 is offline
Default ENGINE
Questions to ask:
Date of manufacture
Total engine time
wide deck or narrow deck
date of major overhaul
who did the overhaul
has the engine been near the coast since overhaul
When was the prop strike event
if the engine has spent most of its life near the coast, walk away
If the major was 20 years ago walk away
Nitride cylinders are notorious for rust pits that turn them into junk. This is especially true if the engine has been sitting around with no preservation treatment.The nitride cylinders are marked with blue paint on cylinder fins just inboard of upper spark plug. I personally would not want an engine that is beyond 4000 hours total time.
Old 02-14-2010, 09:32 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
I suspect that a new engine may be a better "deal."
