ARG - weepy brake fitting
I've been pumping the fluid through my brake lines, and it was all going pretty well, except for one fitting which is leaking through the AN822 elbow fitting pipe thread into the master cylinder (left brake, pilot side). When I pump the brakes, brake fluid weeps out around this fitting from the master cylinder and eventually starts dripping.
I've tried tightening the fitting, and taking it off and applying more fuel lube. No help. It's on there really tight - I'm afraid to tighten it any more for fear of stripping the threads in the master cylinder.
Suggestions?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
