Old 02-10-2010, 06:38 PM
MS19087's Avatar
MS19087 MS19087 is offline
Default FAB Installation - should I be concerned?
I have completed my FAB install (IO-320 w/ Vertical updraft). Despite efforts to insure a tight compressed fit of the air filter between the fiberglass housing and the mounting plate, I appear to have 2 slight gaps. They are approx 1/16" - one in front and on in back. Is this an issue? Should I:
a) leave it alone and not worry that a foreign object less than 1/16" could enter . . .
b) apply a bead of Proseal to fill the gap (I know that RTV may have issues of being sucked in - same concern w/ Proseal??)
c) Build a new FAB - I really don't want to do this . . .
Any other solutions I should consider?? As always, your comments are appreciated!!
Mark
RV-9A; Sold
RV-14A; Building
2020 =VAF= donor
Old 02-10-2010, 06:46 PM
RickWoodall's Avatar
RickWoodall RickWoodall is offline
Default Pic
Hi Mark. We are just doing up our fab box and built the clips, did the cutting etc to fit well. I cannot speak to your issue, but would suggest you post a couple pics of the issue to get better opinions or comments.
I believe RTV on a spot like this would be a no no as it could get sucked in to the engine but...hopefully some smarter folks will chime in.
Rick Woodall C-GSTT "ghost"
9a -TMX io-320, catto three blade, dual dynon hdx with a/p. 900+ hrs in 8 yrs flying.
Flew to Osh 11,12,15,17,19. SNF 2013. West to Cali /Washington/Vancouver/crossed the Rockies north to Red Deer east to Moosonee and over to maritimes. South to Jekyll Isl, cedar key, and Key West etc. 6 trips and 17 islands of the Bahamas. Flown turtles and dogs for Pilots n Paws too. Love our Rv's
Old 02-10-2010, 07:03 PM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default shots in the dark without a photo...
could you just build up the gap with some resin? or perhaps cut a slot or two and use a hose clamp to soak up the free play?
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 02-10-2010, 07:05 PM
AlexPeterson's Avatar
Many have had cracks develop in the bottom of the FAB fiberglass, so the previous post's idea to lay some glass in there is a good one.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 02-10-2010, 07:06 PM
MS19087's Avatar
Default photos coming . . .
I'll shoot some photos tomorrow . . . thanks!
Mark
RV-9A; Sold
RV-14A; Building
2020 =VAF= donor
