Originally Posted by DEWATSON
I am building a RV8 and I'm just about through with the wiring....thank goodness. There is a "keep alive" feature with the Dynon Flightdek 180 and also with the Garmin radio. My battery is in the back of the airplane. Are most of you running a single wire from the battery side of the master switch up to the avionics to provide the "keep alive" voltage needed? Or what would be better? Thanks.
David Watson
49FD
The traditional method of controlling the battery master relay is with a relay that is activated by a switch that switches the ground side of the relay coil. Then there is no need to have an inline fuse located at the relay to protect the wire (because it is a ground wire).
Because it is a ground wire, it is not possible to use it for a memory keep alive on other equipment.
Scott McDaniels
Hubbard, Oregon
