Old 02-09-2010, 08:35 AM
L'Avion's Avatar
L'Avion L'Avion is offline
Default Parachute RV-4 Recommendation?
Any suggestions/recommendations for a chute, front seat RV-4, will be much appreciated.
Barney, in Memphis
Old 02-09-2010, 09:52 AM
Brian Vickers Brian Vickers is offline
Default Most of the seat pack units will work
I have a Strong Enterprises model 304 that fits well, but all the emergency parachute manufactures make a similar unit. The seat pack measures 11" x 15" x 5" thick (actual measurements), and sits down in the area between the seatback and spar nice and snug. I have manual flaps and therefore the seat pack must be positioned slightly right of center, but this does not change comfort or functionality. The parachute is packed very tight so it is like sitting on a rock. It has a thin integral Comforfoam pad with soft fabric cover on the seat and back but its still quite firm. I purchased it on VAF.NET from a retiring RV owner for $750, including shipping. It is ten years old but looks brand new and came with a case and extensive user manual. One data point for you.
Brian Vickers
Bainbridge Island, WA
RV4
Old 02-10-2010, 07:02 PM
L'Avion's Avatar
Strong also makes a #314, specifically for the RV-4; but at 10.5" x 16" wide it does get in the way of manual flaps. The Strong 303 mini (backpack) might work, but at 3" thick, I'm concerned that it will move me too far forward for comfort.
Any other suggestions?
Barney, in Memphis
PS: Moderator, please correct my spelling in the original post/thread. Thanks.
Old 02-10-2010, 07:24 PM
Mel's Avatar
Mel Mel is offline
Gotcha covered.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 02-10-2010, 10:30 PM
nauga nauga is offline
Stock (not RV-4 specific) Strong 304 was the only thing I could find that kept my head off the canopy. The backpack 'chute I had before the 304 put me too far forward (head into the downsloping part of the canopy), other seat-packs lifted me too high. I have a taller-than-average seated height and abnormally large (but somewhat empty) head , YMMV.
Nauga
2004 RV-4
Old 02-10-2010, 10:53 PM
AX-O's Avatar
AX-O AX-O is offline
All,
how do you get out of the plane? I can't figure that out due to the side opening canopy.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 02-11-2010, 07:01 AM
skyfrog's Avatar
skyfrog skyfrog is offline
Default Sun-N-Fun
If you plan to buy a new chute, I'd recommend waiting until Sun-N-Fun. They had a considerable show discount.
John Edwards
jedwards@digital.net
VAF #1089
Old 02-11-2010, 08:19 AM
cguarino cguarino is offline
Default No problem
Originally Posted by AX-O View Post
All,
All you have to do is unlock the canopy and it will depart the aircraft. The hinge is pop riveted on to facilitate this.
Charlie "T.Bear" Guarino
Springtown, TX
RV-4 Flying again with a fresh overhaul
Exempt but paid
Old 02-11-2010, 08:20 AM
Sid Lambert Sid Lambert is offline
All,
You just open the canopy. The rivets on the hinges are soft rivets and will rip right off. It's happened a few times on accident.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 02-12-2010, 09:41 AM
L'Avion's Avatar
Default "National 360"
Has anyone used a "National 360" (good for 177# @ 140kts) in an RV-4 front seat?
Other suggestions?
Barney
